Ga door naar hoofdinhoud
Nikon CoolPix S5 Battery Replacement
Wat je nodig hebt
  1. Nikon CoolPix S5 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Using the thumb, firmly push the SD/Battery cover in the middle and then in the direction of the arrow on the SD/Battery cover.
    • This will cause the SD/Battery cover to pop open.
  2. Nikon CoolPix S5 Battery Replacement: stap 2, afbeelding 1 van 1
    • Press orange clip to eject battery (battery not shown).
  3. Nikon CoolPix S5 Battery Replacement: stap 3, afbeelding 1 van 1
    • While cupping hand under the bottom of the SD/Battery slot, turn the camera upright.
    • This will cause the battery to fall into the hand (battery not shown).
  4. Nikon CoolPix S5 Battery Replacement: stap 4, afbeelding 1 van 1
    • Following the positive and negative placement signs, slide the new battery into the battery slot (battery not shown).
  5. Nikon CoolPix S5 Battery Replacement: stap 5, afbeelding 1 van 1
    • Slide the SD/Battery cover in the reverse direction of the arrow on the SD/Battery cover until it clicks into place.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Patty Richeson
99 Reputatie
4 handleidingen geschreven
Clemson, Team 12-5, Benson Spring 2013 Lid van Clemson, Team 12-5, Benson Spring 2013
CLEM-BENSON-S13S12G5
4 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 16
Altijd: 709
