Inleiding
In order to access any of the inner parts of the camera, the outer case must be taken apart first. [PREREQUISITE ONLY]
Onderdelen
Geen onderdelen opgegeven.
  1. Remove the three 4 mm screws from the bottom of the camera using a #00 Phillips screwdriver.
    • Remove the three 4 mm screws from the bottom of the camera using a #00 Phillips screwdriver.
    • Remove the single 3.5 mm screw from the bottom of the camera using a #00 Phillips screwdriver.
  2. With the bottom of the camera facing you, slide the latch on the compartment to the left. Swing the battery compartment door open.
    • With the bottom of the camera facing you, slide the latch on the compartment to the left.
    • Swing the battery compartment door open.
    • Remove the 3.5 mm screw from the inside with a #00 Phillips screwdriver.
  3. Android Fix Kits
    Slechts één reparatie scheidt jou van een nieuw scherm of een nieuwe batterij.
    Nu winkelen
    Android Fix Kits
    Nu winkelen
  4. With the screen facing you, locate the two 3.5 mm screws on the left face of the camera.  Remove them using a #00 Phillips screwdriver.
    • With the screen facing you, locate the two 3.5 mm screws on the left face of the camera. Remove them using a #00 Phillips screwdriver.
  5. With the screen facing you, locate the three 3.5 mm screws on the right face of the camera.  Remove them with a #00 Phillips screwdriver.
    • With the screen facing you, locate the three 3.5 mm screws on the right face of the camera. Remove them with a #00 Phillips screwdriver.
    • Two of the screws are located under the port tabs.
  6. Locate the crease where the case comes together. Using a plastic prying tool, pry at the line to remove the camera case.
    • Locate the crease where the case comes together.
    • Using a plastic prying tool, pry at the line to remove the camera case.
    • It may take several attempts to remove the case. Remember to pry at all the crease locations on the camera, and not just one spot.
Conclusie
Jim Bui
799 Reputatie
6 handleidingen geschreven
USF Tampa, Team 1-4, Blackwell Winter 2015 Lid van USF Tampa, Team 1-4, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G4
4 Leden
Voeg een opmerking toe
Bekijk statistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Aller tijden: 40
