Ga door naar hoofdinhoud
Nikon COOLPIX S3600 Battery Cover Replacement
Wat je nodig hebt
  1. Nikon COOLPIX S3600 Battery Cover Replacement, Battery Cover: stap 1, afbeelding 1 van 2 Nikon COOLPIX S3600 Battery Cover Replacement, Battery Cover: stap 1, afbeelding 2 van 2
    • Locate the battery cover on the right side of the bottom of the camera.
    • To open the cover, gently slide it in the direction indicated by the arrow.
  2. Nikon COOLPIX S3600 Battery Cover Replacement: stap 2, afbeelding 1 van 3 Nikon COOLPIX S3600 Battery Cover Replacement: stap 2, afbeelding 2 van 3 Nikon COOLPIX S3600 Battery Cover Replacement: stap 2, afbeelding 3 van 3
    • Once the battery cover door is open, insert the pointed end of a spudger underneath the metal door hinge.
    • Gently twist the spudger; the battery door cover should pop off.
    • Completely remove the cover from the hinge.
Conclusie
To reattach the battery cover door, align the metal hinge with the plastic cover and press the plastic cover downward until it snaps into place.
Kim Maxson
101 Reputatie
1 Handleiding geschreven
Colorado Springs, Team 1-3, May Spring 2015 Lid van Colorado Springs, Team 1-3, May Spring 2015
UCCS-MAY-S15S1G3
6 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 14
Altijd: 397
