Ga door naar hoofdinhoud
Nikon COOLPIX P600 Battery Replacement
  1. Nikon COOLPIX P600 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the camera upside down so that the lens is facing away from you.
  2. Nikon COOLPIX P600 Battery Replacement: stap 2, afbeelding 1 van 2 Nikon COOLPIX P600 Battery Replacement: stap 2, afbeelding 2 van 2
    • Slide the switch on the battery cover towards the center of the camera.
  3. Nikon COOLPIX P600 Battery Replacement: stap 3, afbeelding 1 van 2 Nikon COOLPIX P600 Battery Replacement: stap 3, afbeelding 2 van 2
    • Once the battery cover is open, push the solid yellow tab in the direction of the arrow. This will then eject the battery out of the camera.
Conclusie
To reassemble your device, follow these instructions in reverse order. Make sure the battery is pushed back into the battery compartment enough to have the yellow latch seen in step three click back over the top of the battery before attempting to close the battery cover.
Bijgevoegde documenten
Geronimo Gutierrez IV
354 Reputatie
2 handleidingen geschreven
CSU Fullerton, Team 1-5, Bruce Fall 2015 Lid van CSU Fullerton, Team 1-5, Bruce Fall 2015
CSUF-BRUCE-F15S1G5
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 26
Altijd: 2,110
