Ga door naar hoofdinhoud
Nikon COOLPIX P2 WiFi Card Replacement
Wat je nodig hebt
  1. Nikon COOLPIX P2 WiFi Card Replacement, Case: stap 1, afbeelding 1 van 1
    • Remove the screw located near the speaker port using a Phillips 00 screwdriver.
  2. Nikon COOLPIX P2 WiFi Card Replacement: stap 2, afbeelding 1 van 1
    • Turn camera upside down so that the battery compartment is facing you.
    • Remove all four screws from the bottom of the camera with a Phillips 00 screwdriver.
  3. Nikon COOLPIX P2 WiFi Card Replacement: stap 3, afbeelding 1 van 1
    • Rotate the camera to the opposite side where the A/V outlet is located.
    • Unscrew and remove all four screws with a Phillips 00 screwdriver.
  4. Nikon COOLPIX P2 WiFi Card Replacement: stap 4, afbeelding 1 van 1
    • Turn the camera so that the Wi-Fi adapter is facing you.
  5. Nikon COOLPIX P2 WiFi Card Replacement: stap 5, afbeelding 1 van 3 Nikon COOLPIX P2 WiFi Card Replacement: stap 5, afbeelding 2 van 3 Nikon COOLPIX P2 WiFi Card Replacement: stap 5, afbeelding 3 van 3
    • Using a plastic opening tool, pry the front casing of the camera.
    • Continue this motion all around the front casing of the camera.
    • Gently pull apart the front casing from the rest of the camera.
  6. Nikon COOLPIX P2 WiFi Card Replacement: stap 6, afbeelding 1 van 1
    • Using the plastic opening tool pry the back casing of the camera.
  7. Nikon COOLPIX P2 WiFi Card Replacement: stap 7, afbeelding 1 van 1
    • Orange ribbon is fragile
    • Carefully pull apart the back casing of the camera from the front of the camera without tearing the orange ribbon.
  8. Nikon COOLPIX P2 WiFi Card Replacement: stap 8, afbeelding 1 van 2 Nikon COOLPIX P2 WiFi Card Replacement: stap 8, afbeelding 2 van 2
    • Pull down the on the black latch to carefully separate the orange ribbon from the motherboard.
    • Pull apart the orange ribbon and front casing from the rest of the camera.
  9. Nikon COOLPIX P2 WiFi Card Replacement, LCD Screen: stap 9, afbeelding 1 van 2 Nikon COOLPIX P2 WiFi Card Replacement, LCD Screen: stap 9, afbeelding 2 van 2
    • Use plastic opening tool to carefully pry the LCD Screen from the camera.
  10. Nikon COOLPIX P2 WiFi Card Replacement: stap 10, afbeelding 1 van 2 Nikon COOLPIX P2 WiFi Card Replacement: stap 10, afbeelding 2 van 2
    • Gently pull the ribbon cable down to release the latch, then pull up to remove it from the motherboard.
  11. Nikon COOLPIX P2 WiFi Card Replacement: stap 11, afbeelding 1 van 1
  12. Nikon COOLPIX P2 WiFi Card Replacement, WiFi Card: stap 12, afbeelding 1 van 1
    • Continue by removing two screws from the back of the camera body.
  13. Nikon COOLPIX P2 WiFi Card Replacement: stap 13, afbeelding 1 van 1
    • Remove the screw connecting the wifi card cover to the front of the camera.
  14. Nikon COOLPIX P2 WiFi Card Replacement: stap 14, afbeelding 1 van 1
    • Remove the final screw connecting the Wifi card cover to the case.
  15. Nikon COOLPIX P2 WiFi Card Replacement: stap 15, afbeelding 1 van 1
    • Gently pull the Wifi card cover off of the camera body.
  16. Nikon COOLPIX P2 WiFi Card Replacement: stap 16, afbeelding 1 van 1
    • Remove the screw holding the Wifi Card to the camera body.
  17. Nikon COOLPIX P2 WiFi Card Replacement: stap 17, afbeelding 1 van 1
    • Gently pull the WiFi card out of the camera.
Conclusie
Joshua Avery
31 Reputatie
3 handleidingen geschreven
Cal Poly, Team 3-28, Amido Winter 2012 Lid van Cal Poly, Team 3-28, Amido Winter 2012
CPSU-AMIDO-W12S3G28
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 893
