Inleiding
This replacement may be necessary if all other options have been exhausted.
Wat je nodig hebt
Using a Phillips #000 screwdriver, remove the three bottom screws connected to the back plate on the bottom of the device.
Remove the screws under the flaps covering the HDMI and mini USB ports.
Use the plastic opening tool to pry off the connectors shown
Using your finger, pry off the connection flap.
Één andere persoon heeft deze handleiding voltooid.
