Ga door naar hoofdinhoud
Nikon 1 AW 1 Buttons Replacement
Wat je nodig hebt
  1. Nikon 1 AW 1 Buttons Replacement, Buttons: stap 1, afbeelding 1 van 3 Nikon 1 AW 1 Buttons Replacement, Buttons: stap 1, afbeelding 2 van 3 Nikon 1 AW 1 Buttons Replacement, Buttons: stap 1, afbeelding 3 van 3
    • Using the Phillips PH00 screwdriver, remove the six 4.0mm screws marked in red. Then remove the panel cover by lightly pulling it off.
  2. Nikon 1 AW 1 Buttons Replacement: stap 2, afbeelding 1 van 3 Nikon 1 AW 1 Buttons Replacement: stap 2, afbeelding 2 van 3 Nikon 1 AW 1 Buttons Replacement: stap 2, afbeelding 3 van 3
    • Using the Phillips PH00 screwdriver, remove the four 5.5mm screws in the red circles. Then use a plastic opening tool to pry off the tripod socket.
    • Remove the metal plate to have access to the 4.9mm screw under the orange circle, use the Phillips PH00 screwdriver to remove it.
  3. Nikon 1 AW 1 Buttons Replacement: stap 3, afbeelding 1 van 3 Nikon 1 AW 1 Buttons Replacement: stap 3, afbeelding 2 van 3 Nikon 1 AW 1 Buttons Replacement: stap 3, afbeelding 3 van 3
    • Using a T4 head screwdriver remove the three 5.4mm screws marked with the red circles.
    • Use a 1/4" flathead screwdriver or a flat head tool to release the grip attachment screw.
    • Remove the camera strap eyelet.
  4. Nikon 1 AW 1 Buttons Replacement: stap 4, afbeelding 1 van 3 Nikon 1 AW 1 Buttons Replacement: stap 4, afbeelding 2 van 3 Nikon 1 AW 1 Buttons Replacement: stap 4, afbeelding 3 van 3
    • Remove the grip attachment screw.
    • Use a Phillips PH00 to remove the two 2.4mm screws on the grip attachment slot, then remove the slot.
  5. Nikon 1 AW 1 Buttons Replacement: stap 5, afbeelding 1 van 3 Nikon 1 AW 1 Buttons Replacement: stap 5, afbeelding 2 van 3 Nikon 1 AW 1 Buttons Replacement: stap 5, afbeelding 3 van 3
    • Use a T4 screwdriver to remove the three 5.4mm screw marked with the red circles and the eyelet strap.
    • Use a plastic opening tool to lift the front camera cover off.
  6. Nikon 1 AW 1 Buttons Replacement: stap 6, afbeelding 1 van 3 Nikon 1 AW 1 Buttons Replacement: stap 6, afbeelding 2 van 3 Nikon 1 AW 1 Buttons Replacement: stap 6, afbeelding 3 van 3
    • Use a Phillips PH00 to unscrew the two 3.5mm screws in red.
    • Press the flash pop-up button in the orange rectangle to be able to remove top cover of the camera.
  7. Nikon 1 AW 1 Buttons Replacement: stap 7, afbeelding 1 van 3 Nikon 1 AW 1 Buttons Replacement: stap 7, afbeelding 2 van 3 Nikon 1 AW 1 Buttons Replacement: stap 7, afbeelding 3 van 3
    • Use a plastic opening tool to lift off the top panel.
  8. Nikon 1 AW 1 Buttons Replacement: stap 8, afbeelding 1 van 1
    • If you needed to replace any buttons, you may now do so by pulling them off.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Lester Rodriguez Piti
373 Reputatie
3 handleidingen geschreven
USF Tampa, Team 3-4, Sullivan Fall 2016 Lid van USF Tampa, Team 3-4, Sullivan Fall 2016
USFT-SULLIVAN-F16S3G4
4 Leden
6 handleidingen geschreven
Één opmerking
What if the flash button is not working? How will i open or fix it? Flash does not pop out
Noel Marantan - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 9
Altijd: 780
