Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
The Car, the Remote Control and a Phillips screwdriver.
The rear wing
Unscrew this black screws
Remove the wing
The Exhausts
Remove these screws
Remove the exhausts
The "tubolar" body
Flip the car
Remove these screws.
Remove the body
The seat
Remove these screws (one of these is back of the seat)
Remove the seat.
The antenna
Remove this screw
Raise the circuit board
Remove the antenna
The "engine"
Remove these screws
Remove the gears cover
Remove the engine block
Remove the gear and his hinge
Remove this piece of plastic
The Engine!
The Steering Mechanism
Remove these screws
Remove the cover
Lift the wheels
Remove the steering bar...
...the two screws...
...and the cover.
Remove the steering motor
Remove the plastic cover
Remove this piece
Remove the second piece...
...and the spring.
Congratulations! The car is torn down!
Remove the screw in the PCB
Remove the screw in the piece of plastic at the end of the antenna
Remove the plastic piece around the beginning of the antenna
Detach the two parts of eat key.
Congratulations! You've ended the teardown!
