Ga door naar hoofdinhoud
Nike+ Sportband Motherboard Replacement
Wat je nodig hebt
  1. Nike+ Sportband Motherboard Replacement, External Case: stap 1, afbeelding 1 van 2 Nike+ Sportband Motherboard Replacement, External Case: stap 1, afbeelding 2 van 2
    • To begin the disassembly of your NikePlus Sportband, first remove the device from the rubber wristband.
  2. Nike+ Sportband Motherboard Replacement: stap 2, afbeelding 1 van 2 Nike+ Sportband Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Finish the disassembly of your NikePlus Sportband by utilizing the metal spudger tool on the short edge to pry the external body pieces apart.
  3. Nike+ Sportband Motherboard Replacement, Screen: stap 3, afbeelding 1 van 2 Nike+ Sportband Motherboard Replacement, Screen: stap 3, afbeelding 2 van 2
    • After the cover had been removed, use the metal spudger tool to remove the body of the device from the casing.
  4. Nike+ Sportband Motherboard Replacement: stap 4, afbeelding 1 van 3 Nike+ Sportband Motherboard Replacement: stap 4, afbeelding 2 van 3 Nike+ Sportband Motherboard Replacement: stap 4, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Use the metal tweezers to pry the screen casing from the body of the device.
    • The screen casing is fastened to the body of the device by four clips located in each corner of the casing.
  5. Nike+ Sportband Motherboard Replacement: stap 5, afbeelding 1 van 2 Nike+ Sportband Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Flip the body of the device over so that the screen is now on the bottom.
    • The display ribbon cable is soldered to the motherboard. We were able to peel up the ribbon cable with a pair of tweezers.
    • Successfully resoldering this ribbon cable to the motherboard may prove difficult to the very small traces.
  6. Nike+ Sportband Motherboard Replacement: stap 6, afbeelding 1 van 3 Nike+ Sportband Motherboard Replacement: stap 6, afbeelding 2 van 3 Nike+ Sportband Motherboard Replacement: stap 6, afbeelding 3 van 3
    • Flip the body of the device back over so that the screen is facing up.
    • Using the tweezers, gently lift the screen from body of the device.
  7. Nike+ Sportband Motherboard Replacement, Motherboard: stap 7, afbeelding 1 van 1
    • Remove the four highlighted screws from the motherboard using the Philips screwdriver.
  8. Nike+ Sportband Motherboard Replacement: stap 8, afbeelding 1 van 3 Nike+ Sportband Motherboard Replacement: stap 8, afbeelding 2 van 3 Nike+ Sportband Motherboard Replacement: stap 8, afbeelding 3 van 3
    Koop
    • Use the metal tweezers to lift the motherboard out of the device.
Conclusie
Alyssa Setnar
331 Reputatie
3 handleidingen geschreven
IUPUI, Team 9-9, Wilson Spring 2016 Lid van IUPUI, Team 9-9, Wilson Spring 2016
IUPUI-WILSON-S16S9G9
5 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 265
