Ga door naar hoofdinhoud
Nexus S Motherboard Replacement
Wat je nodig hebt
  1. Nexus S Motherboard Replacement, Rear Panel: stap 1, afbeelding 1 van 1
    • Gently insert a plastic opening tool between the rear panel and the inner rear frame near the rear-facing camera.
    • Use your plastic opening tool to pry up the rear case around the perimeter of the Nexus S.
  2. Nexus S Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Remove the rear panel from the Nexus S.
  3. Nexus S Motherboard Replacement, Battery: stap 3, afbeelding 1 van 1
    • Using the edge of a plastic opening tool, lift the battery from the end closest to the headphone jack.
    • Remove the battery from the Nexus S.
  4. Nexus S Motherboard Replacement, SIM Card: stap 4, afbeelding 1 van 2 Nexus S Motherboard Replacement, SIM Card: stap 4, afbeelding 2 van 2
    • Use your thumb to slide the SIM card downwards from the SIM card slot.
    • Remove the SIM card.
  5. Nexus S Motherboard Replacement, Rear Inner Frame: stap 5, afbeelding 1 van 1
    • Remove the six Phillips screws securing the rear inner frame to the inner case.
  6. Nexus S Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Insert the flat edge of a plastic opening tool in between the rear inner frame and the top left corner of the Nexus S.
    • Pry the opening tool upwards to pop the top right corner from the clips securing it to the inner assembly.
  7. Nexus S Motherboard Replacement: stap 7, afbeelding 1 van 2 Nexus S Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Insert the plastic opening tool to the right of the power button.
    • Slide the plastic opening tool downwards along the perimeter of the Nexus S to release the clips on the right side.
  8. Nexus S Motherboard Replacement: stap 8, afbeelding 1 van 2 Nexus S Motherboard Replacement: stap 8, afbeelding 2 van 2
    • In the same manner as previously described, release the bottom clips located near the bottom of the Nexus S.
  9. Nexus S Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Insert and pry the plastic opening tool to release the final clip securing the rear inner frame to the inner assembly.
  10. Nexus S Motherboard Replacement: stap 10, afbeelding 1 van 1
    • Lift and remove the rear inner frame from the Nexus S.
  11. Nexus S Motherboard Replacement, Motherboard: stap 11, afbeelding 1 van 1
    • Disconnect the following cables from their respective sockets on the motherboard:
    • Headphone jack cable
    • Digitizer cable connector
    • Camera/SIM board connector
  12. Nexus S Motherboard Replacement: stap 12, afbeelding 1 van 3 Nexus S Motherboard Replacement: stap 12, afbeelding 2 van 3 Nexus S Motherboard Replacement: stap 12, afbeelding 3 van 3
    • Insert the flat edge of a plastic opening tool underneath the headphone jack connector and pry upwards.
    • Make sure to pry on the connector and not the socket itself. Prying the socket may cause severe damage.
    • Repeat the procedure for the digitizer and rear camera/SIM board connectors.
  13. Nexus S Motherboard Replacement: stap 13, afbeelding 1 van 1
    • Remove the three Phillips screws securing the motherboard to the front display assembly.
  14. Nexus S Motherboard Replacement: stap 14, afbeelding 1 van 2 Nexus S Motherboard Replacement: stap 14, afbeelding 2 van 2
    • Wedge the plastic opening tool near the bottom right corner of the motherboard and pry upwards to dislodge it from its recess.
    • Lift and remove the motherboard.
Conclusie
15 andere personen hebben deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 9
Altijd: 13,708
