Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Squeeze and pull the cap to remove it from the Nexus Q.
Use a spudger to disconnect the Taoglas Wi-Fi Dual Band Antenna.
Undo the ZIF connector by prying it with a spudger.
Use a Phillips #0 screwdriver to unscrew the four 1.3 mm screws.
View the bottom half of the Nexus Q.
Use a Phillips #0 screwdriver to remove the four 0.8 mm screws holding the ball bearing ring in place.
Once you remove the ball bearing ring from the bottom half of the Nexus Q, you will be exposed to a diffuser (white ring) held in with three T6 Torx screws.
Use a #0 Philips head screwdriver to remove the three 0.8 mm screws holding the diffuser in place.
With the diffuser out, we are exposed to the LED Board.
Use a spudger to lightly lift the LED board out.
