Ga door naar hoofdinhoud
Nexus One Vibrator Replacement
Wat je nodig hebt
  1. Nexus One Vibrator Replacement, Lower Cover: stap 1, afbeelding 1 van 2 Nexus One Vibrator Replacement, Lower Cover: stap 1, afbeelding 2 van 2
    • Using the plastic opening tool, push the blade into the space between the case and lower cover.
    • Turn the opening tool slightly, the lower cover will detach on that side.
    • Repeat on other side of the seam.
    • The lower cover will slide off.
  2. Nexus One Vibrator Replacement, Antenna Housing: stap 2, afbeelding 1 van 1
    • Remove the one T5 Torx screw
    • Remove the one #00 Philips screw
    • Lift up the end of the antenna housing and slide it outwards.
    • The vibrator is located on the back of the antenna housing.
    • Use the spudger to pry up on the axle of the motor.
Conclusie
Niklas Johnson
1.207 Reputatie
18 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 1,688
