1. Using two fingers, push up on the rear cover. Using two fingers, push up on the rear cover.
    • Using two fingers, push up on the rear cover.
  2. The rear cover slides up and off.
    • The rear cover slides up and off.
  3. Using the plastic opening tools, pry the left bottom corner of the battery up.
    • Using the plastic opening tools, pry the left bottom corner of the battery up.
  4. Pull the battery up and out.
    • Pull the battery up and out.
  5. Remove the two Torx T5 screws.
    • Remove the two Torx T5 screws.
    • Remove the one Philips #00 screw.
  6. Using the plastic opening tool, pry up the battery housing upwards. Push pry tool down, undoing the plastic tab.
    • Using the plastic opening tool, pry up the battery housing upwards.
    • Push pry tool down, undoing the plastic tab.
  7. Pry the upper left tab open on the battery housing. Pry the upper left tab open on the battery housing.
    • Pry the upper left tab open on the battery housing.
  8. Pry the top tab of the battery housing. Pry the top tab of the battery housing.
    • Pry the top tab of the battery housing.
  9. Pry the right side tab of the battery housing. Pry the right side tab of the battery housing.
    • Pry the right side tab of the battery housing.
  10. Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  11. Pull up on the battery housing. Slide the battery housing out to remove it.
    • Pull up on the battery housing.
    • Slide the battery housing out to remove it.
  12. Using the plastic opening tool, push the blade into the space between the case and lower cover. Turn the opening tool slightly, the lower cover will detach on that side.
    • Using the plastic opening tool, push the blade into the space between the case and lower cover.
    • Turn the opening tool slightly, the lower cover will detach on that side.
    • Repeat on other side of the seam.
    • The lower cover will slide off.
  13. Remove the one T5 Torx screw
    • Remove the one T5 Torx screw
    • Remove the one #00 Philips screw
    • Lift up the end of the antenna housing and slide it outwards.
  14. Using the spudger, pry upwards on the second microphone connector. Using the spudger, pry upwards on the second microphone connector.
    • Using the spudger, pry upwards on the second microphone connector.
  15. Pull up on the ribbon cable, the tape will detach from the main board ribbon.
    • Pull up on the ribbon cable, the tape will detach from the main board ribbon.
  16. Pry the antenna cable up. Pry the antenna cable up.
    • Pry the antenna cable up.
  17. Carefully pull up on the microphone board to release the tape from the phone.
    • Carefully pull up on the microphone board to release the tape from the phone.
  18. Insert the spudger under the connector. Push the spudger up and twist to release the connector.
    • Insert the spudger under the connector.
    • Push the spudger up and twist to release the connector.
    • Repeat for the next connector.
  19. Push on the USB port to expose the black connector. Use the spudger to pry the connector upwards. Use the spudger to pry the connector upwards.
    • Push on the USB port to expose the black connector.
    • Use the spudger to pry the connector upwards.
  20. Place the spugder under the antenna connector. Pry connector up vertically.
    • Place the spugder under the antenna connector.
    • Pry connector up vertically.
  21. Insert the spudger into tab above the camera. Slide upwards until the board detaches from the case. Slide upwards until the board detaches from the case.
    • Insert the spudger into tab above the camera.
    • Slide upwards until the board detaches from the case.
  22. Press the pointed tip of the spudger into the space below the button assembly.
    • Press the pointed tip of the spudger into the space below the button assembly.
    • Wiggle the spudger tip towards the outside of the button.
    • The button assembly is under some tension and may fly off.
  23. Push the pointed tip of the spudger into the base of the side button board.
    • Push the pointed tip of the spudger into the base of the side button board.
    • Lift up, the board will disconnect from the case.
  24. Push on the lower motherboard until it slides under the case support. The motherboard assembly comes out as a single piece. Save the small black rubber rectangular sound guide under the motherboard, to replace over the microphone.
    • Push on the lower motherboard until it slides under the case support.
    • The motherboard assembly comes out as a single piece.
    • Save the small black rubber rectangular sound guide under the motherboard, to replace over the microphone.
    • Remove the three #00 Philips screws from the trackball housing.
  25. Using the spudger, pry up the trackball housing to expose the trackball assembly.
    • Using the spudger, pry up the trackball housing to expose the trackball assembly.
    • The trackball pushes out from the outside of the phone.
    • The trackball assembly only mounts a single way. The metal tab under the ball should hinge closest to the bottom of the phone. (RE-EDIT)
Conclusie
Niklas Johnson
1.063 Reputatie
18 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 2
Altijd: 3,232
