Ga door naar hoofdinhoud
Nexus One Secondary Microphone Replacement
Wat je nodig hebt
  1. Nexus One Secondary Microphone Replacement, Rear Cover: stap 1, afbeelding 1 van 2 Nexus One Secondary Microphone Replacement, Rear Cover: stap 1, afbeelding 2 van 2
    • Using two fingers, push up on the rear cover.
  2. Nexus One Secondary Microphone Replacement: stap 2, afbeelding 1 van 1
    • The rear cover slides up and off.
  3. Nexus One Secondary Microphone Replacement, Battery: stap 3, afbeelding 1 van 1
    • Using the plastic opening tools, pry the left bottom corner of the battery up.
  4. Nexus One Secondary Microphone Replacement: stap 4, afbeelding 1 van 1
    • Pull the battery up and out.
  5. Nexus One Secondary Microphone Replacement, Battery Housing: stap 5, afbeelding 1 van 1
    • Remove the two Torx T5 screws.
    • Remove the one Philips #00 screw.
  6. Nexus One Secondary Microphone Replacement: stap 6, afbeelding 1 van 2 Nexus One Secondary Microphone Replacement: stap 6, afbeelding 2 van 2
    • Using the plastic opening tool, pry up the battery housing upwards.
    • Push pry tool down, undoing the plastic tab.
  7. Nexus One Secondary Microphone Replacement: stap 7, afbeelding 1 van 2 Nexus One Secondary Microphone Replacement: stap 7, afbeelding 2 van 2
    • Pry the upper left tab open on the battery housing.
  8. Nexus One Secondary Microphone Replacement: stap 8, afbeelding 1 van 2 Nexus One Secondary Microphone Replacement: stap 8, afbeelding 2 van 2
    • Pry the top tab of the battery housing.
  9. Nexus One Secondary Microphone Replacement: stap 9, afbeelding 1 van 2 Nexus One Secondary Microphone Replacement: stap 9, afbeelding 2 van 2
    • Pry the right side tab of the battery housing.
  10. Nexus One Secondary Microphone Replacement: stap 10, afbeelding 1 van 2 Nexus One Secondary Microphone Replacement: stap 10, afbeelding 2 van 2
    • Pull up on the battery housing.
    • Slide the battery housing out to remove it.
  11. Nexus One Secondary Microphone Replacement, Secondary Microphone: stap 11, afbeelding 1 van 2 Nexus One Secondary Microphone Replacement, Secondary Microphone: stap 11, afbeelding 2 van 2
    • Using the spudger, pry upwards on the second microphone connector.
  12. Nexus One Secondary Microphone Replacement: stap 12, afbeelding 1 van 1
    • Pull up on the ribbon cable, the tape will detach from the main board ribbon.
Conclusie
Niklas Johnson
1.207 Reputatie
18 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 2,333
