Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Using the plastic opening tools, pry the left bottom corner of the battery up.
Remove the two Torx T5 screws.
Remove the one Philips #00 screw.
Using the plastic opening tool, pry up the battery housing upwards.
Push pry tool down, undoing the plastic tab.
Pry the upper left tab open on the battery housing.
Pull up on the battery housing.
Slide the battery housing out to remove it.
Insert the spudger under the bottom of the flash board
Twist the spudger to lift and release the flash board.
