Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
installing the flash
  1. Using two fingers, push up on the rear cover. Using two fingers, push up on the rear cover.
    • Using two fingers, push up on the rear cover.
  2. The rear cover slides up and off.
    • The rear cover slides up and off.
  3. Using the plastic opening tools, pry the left bottom corner of the battery up.
    • Using the plastic opening tools, pry the left bottom corner of the battery up.
  4. Pull the battery up and out.
    • Pull the battery up and out.
  5. OPEN ALLE TABBLADEN
    RAM-upgradekits voor Mac
    Koop kits
    Genoeg RAM
    voor al je tabbladen
    Koop kits
  6. Remove the two Torx T5 screws.
    • Remove the two Torx T5 screws.
    • Remove the one Philips #00 screw.
  7. Using the plastic opening tool, pry up the battery housing upwards. Push pry tool down, undoing the plastic tab.
    • Using the plastic opening tool, pry up the battery housing upwards.
    • Push pry tool down, undoing the plastic tab.
  8. Pry the upper left tab open on the battery housing. Pry the upper left tab open on the battery housing.
    • Pry the upper left tab open on the battery housing.
  9. Pry the top tab of the battery housing. Pry the top tab of the battery housing.
    • Pry the top tab of the battery housing.
  10. Pry the right side tab of the battery housing. Pry the right side tab of the battery housing.
    • Pry the right side tab of the battery housing.
  11. Pull up on the battery housing. Slide the battery housing out to remove it.
    • Pull up on the battery housing.
    • Slide the battery housing out to remove it.
  12. Insert the spudger under the bottom of the flash board
    • Insert the spudger under the bottom of the flash board
    • Twist the spudger to lift and release the flash board.
Conclusie
Niklas Johnson
1.093 Reputatie
18 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 1,732
