Inleiding
The Nexus 7 uses a pair of microphone to cancel out ambient noise to improve voice recognition. A broken microphone is really annoying, so be sure to use this guide to help you replace the upper microphone.
Wat je nodig hebt
Using the tip of a spudger, push first on one side then the other to "walk" the battery cable straight out of its socket on the motherboard.
Peel back the copper ESD shielding covering the bottom of the motherboard.
If you're just replacing the micro usb charge port, there is no need to peel back the copper heatsink like in the photo, the speaker assembly can simply be moved out of the way once unscrewed. If the speakers are to be replaced simply peel back the bottom corner to expose the speaker connection. Leave the rest of the heatsink shield alone.
Peel back the label covering the power and volume button ZIF connector.
Carefully peel back the adhesive tape covering the I/O board ribbon cable socket on the motherboard.
Gently pull the upper microphone straight up off its socket located on the back of the motherboard.
