Inleiding
Lack of sound got you down? Use this guide to replace a damaged or broken speaker assembly.
Gereedschap
Onderdelen
Using the tip of a spudger, push first on one side then the other to "walk" the battery cable straight out of its socket on the motherboard.
Peel back the copper ESD shielding covering the bottom of the motherboard.
If you're just replacing the micro usb charge port, there is no need to peel back the copper heatsink like in the photo, the speaker assembly can simply be moved out of the way once unscrewed. If the speakers are to be replaced simply peel back the bottom corner to expose the speaker connection. Leave the rest of the heatsink shield alone.
Remove the following screws securing the speaker assembly to the display assembly:
Two 4.25 mm black Phillips screws
One 3.2 mm silver Phillips screw
36 andere personen hebben deze handleiding voltooid.
7 Opmerkingen
Bobski, if you're not covered under warranty then you'll have to buy the speaker assembly on your own, from eBay or a third party site. They're kind of rare.
EXCELLENT guide, had no issues replacing mine and works great! Thanks iFixit!
Guide was great! Worked perfectly. Thank you!
