Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Heat up back glass panel.
Use hobby knife to open a gap and cut the fierce sticker underneath rear glass panel.
Remove back glass panel carefully.
Heat up bottom plastic panel.
Use hobby knife to open a gap and insert guitar picks to cut adhesive underneath.
Gereedschap gebruikt in deze stap:Heavy-Duty Suction Cups (Pair)$14.95-
Twist off 6 Phillips screws together.
Insert guitar picks and plastic opening tool to separate front assembly from back cover.
Unscrew one Phillips screw.
Remove metal bracket securing flex contactors.
Release 3 flex contactors and remove it .
Gereedschap gebruikt in deze stap:Plastic Cards$2.99-
Release battery contactor.
Use plastic card to cut strong adhesive underneath, then pry up and remove battery.
Here we can see the strong sticker underneath 3450 mAh battery.
Disconnect signal cable contactor and twist off one Phillips screw.
Remove daughterboard.
Cut adhesive underneath vibration motor, then remove vibrator.
Twist off one Phillips screw and remove loudspeaker.
Twist off 2 Phillips screws.
Remove metal bracket securing front camera contactor and audio jack contactor,
Twist off 3 Phillips screws.
Take away metal bracket securing LCD flex contactor.
Release LCD flex connector.
The sticker underneath LCD with digitizer is a little bit strong, so use heat gun to soften it for a few minutes.
With the help of suction cup, plastic opening tool and guitar picks, remove LCD assembly carefully.
9 opmerkingen
Its single sim slot sorry
Ya its haveing to sim slot but there is only 1 antina
There is a thin lining of plastic around the screen. Does removing it deteriorate the structural integrity of the screen or is it simply cosmetic?
Sorry if this is the wrong place to ask.
