Ga door naar hoofdinhoud
Inleiding
Use this guide to replace the back cover in your Nexus 6P smartphone. When reassembling apply new adhesive where it's necessary.
  1. It is possible to remove the back cover with an iOpener as seen in this guide but it's a lengthy and difficult procedure. We recommend a heat gun or something similar. The adhesive in the Nexus 6P is extremely sticky and especially the glass and plastic cover on the backside break or bend most of the time whilst doing this repair. Use a SIM card eject tool, to pop out and remove the SIM card tray. Use an iOpener to loosen the adhesive underneath the small plastic cover at the bottom of the phone.
    • It is possible to remove the back cover with an iOpener as seen in this guide but it's a lengthy and difficult procedure. We recommend a heat gun or something similar. The adhesive in the Nexus 6P is extremely sticky and especially the glass and plastic cover on the backside break or bend most of the time whilst doing this repair.
    • Use a SIM card eject tool, to pop out and remove the SIM card tray.
    • Use an iOpener to loosen the adhesive underneath the small plastic cover at the bottom of the phone.
  2. The knife is really sharp. Take care, not to cut yourself or your phone. Insert a knife between the phone and the plastic cover. Pry up the plastic cover until you can insert an opening pick. Slide the opening pick underneath the plastic cover to cut the adhesive.
    • The knife is really sharp. Take care, not to cut yourself or your phone.
    • Insert a knife between the phone and the plastic cover. Pry up the plastic cover until you can insert an opening pick.
    • Slide the opening pick underneath the plastic cover to cut the adhesive.
  3. Use an iOpener to loosen the adhesive underneath the glass cover at the top of the phone. Insert a knife between the phone and the glass cover. Pry up the glass cover until you can insert an opening pick.
    • Use an iOpener to loosen the adhesive underneath the glass cover at the top of the phone.
    • Insert a knife between the phone and the glass cover. Pry up the glass cover until you can insert an opening pick.
  4. Glass may break. Wear protective glasses and protective gloves. Slide the opening pick underneath the glass cover and use it to cut the adhesive underneath. Pry off the glass cover.
    • Glass may break. Wear protective glasses and protective gloves.
    • Slide the opening pick underneath the glass cover and use it to cut the adhesive underneath.
    • Pry off the glass cover.
  5. Remove the six Phillips #00 screws. Use tweezers to remove any stickers covering the screw to allow better seating for the driver. Use tweezers to remove any stickers covering the screw to allow better seating for the driver.
    • Remove the six Phillips #00 screws.
    • Use tweezers to remove any stickers covering the screw to allow better seating for the driver.
  6. Insert a razor knife between the metal back cover and the front glass to create a gap. Insert an opening pick into the gap and slide it to the top right corner. The knife is really sharp, be careful, not to cut yourself or your phone. Insert a second opening pick and slide it to the top left corner.
    • Insert a razor knife between the metal back cover and the front glass to create a gap. Insert an opening pick into the gap and slide it to the top right corner.
    • The knife is really sharp, be careful, not to cut yourself or your phone.
    • Insert a second opening pick and slide it to the top left corner.
    • Slide the opening picks along the edges to seperate the plastic clips, holding back cover and midframe together.
    • Remove the rear cover.
Conclusie
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
11 andere personen hebben deze handleiding voltooid.
Dominik Schnabelrauch
94.375 Reputatie
387 handleidingen geschreven
iFixit Lid van iFixit
Community
137 Leden
16.425 handleidingen geschreven
Één commentaar
The first picture of Step-6 is very misleading when looking at guitar pick.
By mistake, I pulled apart my front glass from digitizer by taking the pic as reference.
Vijay Bhaskar - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 12
Altijd: 3,282
