Ga door naar hoofdinhoud
Nexus 6 Motherboard Replacement
Wat je nodig hebt
  1. Nexus 6 Motherboard Replacement, SIM Card: stap 1, afbeelding 1 van 1
    • With a SIM card eject tool (a paperclip will work as well), push down on the hole at the top of the phone until the SIM card holder releases. This should not take much pressure.
    • Remove the SIM card and the SIM card holder.
    • Lay out a soft cloth on your workspace to prevent scratching the screen in this and future steps.
    • Pry open the back casing using the soft plastic opening pick.
    • Be careful of the Power & Volume Key ribbon on the left side just next to the volume key. The ribbon is exposed and could be damaged with the opening tool.
    • Carefully pull the back casing apart from the rest of the phone with your hands. Because the casing is glued to the rest of the phone, this step may require some force. Don't be alarmed if the casing flexes a bit.
    • You may need an iOpener to loosen up the adhesive. Check out the Instructies voor de iOpener for info on how to use it.
  2. Nexus 6 Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Remove the twenty-two 2.3 mm T3 Torx screws with the T3 Torx Screwdriver.
  3. Nexus 6 Motherboard Replacement: stap 4, afbeelding 1 van 3 Nexus 6 Motherboard Replacement: stap 4, afbeelding 2 van 3 Nexus 6 Motherboard Replacement: stap 4, afbeelding 3 van 3
    • With tweezers, remove the rubber protector on the lower part of the phone.
    • Disconnect the battery connector by gently prying it straight up with a spudger, on the side opposite the cable.
    • Completely separate the battery side from the motherboard side by gently pulling the sides apart with your hands.
  4. Nexus 6 Motherboard Replacement, Front Facing Camera: stap 5, afbeelding 1 van 1
    • Use a spudger to gently detach the front facing camera connector.
    • Remove the front facing camera using the tweezers.
  5. Nexus 6 Motherboard Replacement, Rear Facing Camera: stap 6, afbeelding 1 van 2 Nexus 6 Motherboard Replacement, Rear Facing Camera: stap 6, afbeelding 2 van 2
    • Use the spudger to release the rear facing camera connector.
    • Use tweezers to gently remove the rear facing camera.
  6. Nexus 6 Motherboard Replacement, Motherboard: stap 7, afbeelding 1 van 2 Nexus 6 Motherboard Replacement, Motherboard: stap 7, afbeelding 2 van 2
    • With a spudger, unlatch the ZIF connector for the smallest ribbon cable in the center. See instructions for detatching ZIF connectors here
    • Use tweezers to release the ribbon cable.
  7. Nexus 6 Motherboard Replacement: stap 8, afbeelding 1 van 2 Nexus 6 Motherboard Replacement: stap 8, afbeelding 2 van 2
    • With a spudger, unlatch the ZIF connector of the big ribbon cable on the side of the phone. See instructions for detatching ZIF connectors here.
    • Use tweezers to release the ribbon cable completely.
    • This connector and the ribbon are attached with a piece of amber anti-static tape. Make sure to release the tape from the ribbon before to pull it out of the connector.
  8. Nexus 6 Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Remove the 2.3 mm T3 Torx screw on the top of the phone.
  9. Nexus 6 Motherboard Replacement: stap 10, afbeelding 1 van 1
    • Peel the motherboard off of the screen with your hands.
Conclusie
13 andere personen hebben deze handleiding voltooid.
Marina Moore
4.284 Reputatie
7 handleidingen geschreven
Cal Poly, Team 70-3, Forte Winter 2015 Lid van Cal Poly, Team 70-3, Forte Winter 2015
CPSU-FORTE-W15S70G3
4 Leden
30 handleidingen geschreven
Één opmerking
It worked great. Thanks!!!
Dustin French - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 34
Altijd: 9,169
