Ga door naar hoofdinhoud
Nexus 5 SIM Card Replacement
Wat je nodig hebt
  1. Nexus 5 SIM Card Replacement, SIM Card: stap 1, afbeelding 1 van 2 Nexus 5 SIM Card Replacement, SIM Card: stap 1, afbeelding 2 van 2
    • Power off the device by holding the power button until the "Power Off" popup appears. Tap the popup and wait for the device to turn off.
    • Insert a SIM card eject tool or a paper clip into the hole next to the SIM card slot, which is located just under the power button. Do not force the paper clip if it is too thick; instead use the head of a sewing needle.
    • Push the tool into the hole until you see the card pop out.
  2. Nexus 5 SIM Card Replacement: stap 2, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Gently remove the SIM card with your fingers, or a pair of tweezers if the SIM holder does not fully eject.
    • Make sure the chip is facing the rear of the phone when reinserting the SIM card.
Conclusie
Kyle Libby
1.006 Reputatie
7 handleidingen geschreven
Cal Poly, Team 7-23, Regan Spring 2014 Lid van Cal Poly, Team 7-23, Regan Spring 2014
CPSU-REGAN-S14S7G23
4 Leden
19 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 23
Altijd: 4,003
