Inleiding
I bought a kit to fix this component. The kit contained the headphone jack itself, a Phillips #00 Screwdriver and an Opening Tool.
I made do with just the above tools, but my instructions use the ideal tools should you have them.
I also replaced the rear camera at the same time, by following the excellent guide for that component.
Wat je nodig hebt
Insert a SIM card eject tool or a paper clip into the hole next to the SIM card slot, which is located just under the power button. Do not force the paper clip if it is too thick; instead use the head of a sewing needle.
Push the tool into the hole until you see the card pop out.
Use a plastic opening tool to free the clips on the top and each side of the back cover.
Remove the six 4.0 mm Phillips #00 screws that secure the midframe to the phone.
To replace the LCD screen and digitizer, remove the additional four 4.0mm daughterboard cover screws with the same screwdriver. You may have to pierce through clear adhesive material to remove them.
Use the flat end of a nylon spudger to disconnect the battery connector.
Use a spudger or tweezers to pull the headphone jack upward and out of the phone.
Place the new headphone jack by orienting it like the old one and pressing it gently down into the phone.
6 andere personen hebben deze handleiding voltooid.
