Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Use a plastic opening tool to free the clips on the top and each side of the back cover.
Remove the six 4.0 mm Phillips #00 screws that secure the midframe to the phone.
To replace the LCD screen and digitizer, remove the additional four 4.0mm daughterboard cover screws with the same screwdriver. You may have to pierce through clear adhesive material to remove them.
Gereedschap gebruikt in deze stap:Spudger$2.99-
Use the flat end of a nylon spudger to disconnect the battery connector.
Use the flat end of a spudger to disconnect the daughterboard ribbon cable and pull it away from the battery.
Use a plastic opening tool to pry the battery out of its housing.
If replacing the battery, bag the old battery up and recycle responsibly at a suitable location.
465 andere personen hebben deze handleiding voltooid.
66 opmerkingen
Did it in less than 10 mins..
Already had experience with taking the backcover off...
In the start of the guide it says "Replace the battery in your iPhone 5s"
After battery replacement my wireless charging was not working. Pay attention to settle holding clip in the middle of phone - just firmly press around the "S" from the back of phone until you hear it clicks in.
Thank you so much for this tip! I did it and it worked. Now Wireless charging is working again.
QNZ -
