Ga door naar hoofdinhoud
Nexus 5 Back Cover Replacement
Wat je nodig hebt
  1. Nexus 5 Back Cover Replacement, Back Cover: stap 1, afbeelding 1 van 3 Nexus 5 Back Cover Replacement, Back Cover: stap 1, afbeelding 2 van 3 Nexus 5 Back Cover Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Use a plastic opening tool to free the clips on the top and each side of the back cover.
    • The bottom is secured with some adhesive foam. You should be able to finally free the back cover using an opening pick. The "snaps" at the bottom edge are more like hinges, so release all others then swing the back cover off outward from the top, and these fasteners will release without breaking.
    • It's best to avoid prying around the SIM card slot and volume controls, as the plastic in these areas is very thin and likely to break from prying.
    • When you replace the cover, there is a snap about even with the flash window that must also be attached (one of three that secure the back cover to the midframe). Qi (wireless) charging may not work if this isn't secure. Apply gentle but firm pressure over the "S" in "Nexus" and slide your thumb up towards the top, and the snap will engage.
Conclusie
43 andere personen hebben deze handleiding voltooid.
Gaetan
9.613 Reputatie
18 handleidingen geschreven
5Gids Commentaar
Where do you find backs for the Nexus 5? Thanks!
Mark Brown - Antwoord Deel
You can find them on Ebay
christian colon - Antwoord Deel
can you tell me if removing the cover of the nexus 5 GPS stops working well?
daniele neri - Antwoord Deel
Back cover LG spare part numbers are:
Black: ACQ86691011
White: ACQ86691012
Red: ACQ86691013
Google them. Done.
nexus555 - Antwoord Deel
Thank you very much.
Jesse Wind - Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 93
Altijd: 73,253
