Ga door naar hoofdinhoud
Nexus 5 Antenna Cable Replacement
Wat je nodig hebt
  1. Nexus 5 Antenna Cable Replacement, Remove the Battery Door: stap 1, afbeelding 1 van 1
    • The battery door of the Nexus 5 is held together with plastic clips.
    • Use the plastic spudger to separate the battery door.
  2. Nexus 5 Antenna Cable Replacement, Unscrew the Midframe and Speaker Assemby: stap 2, afbeelding 1 van 3 Nexus 5 Antenna Cable Replacement, Unscrew the Midframe and Speaker Assemby: stap 2, afbeelding 2 van 3 Nexus 5 Antenna Cable Replacement, Unscrew the Midframe and Speaker Assemby: stap 2, afbeelding 3 van 3
    • Using your #00 Philips Screwdriver, remove the six screws holding the midframe in place.
    • Remove the four screws at the bottom of the device holding the speaker assembly in place.
    • The screw on the far right may be covered in adhesive. Use your plastic spudger to remove the adhesive covering the screw.
  3. Nexus 5 Antenna Cable Replacement, Remove the Midframe and Speaker Assembly: stap 3, afbeelding 1 van 2 Nexus 5 Antenna Cable Replacement, Remove the Midframe and Speaker Assembly: stap 3, afbeelding 2 van 2
    • Remove the midframe and speaker assembly.
  4. Nexus 5 Antenna Cable Replacement, Remove and Replace the Antenna Cables: stap 4, afbeelding 1 van 3 Nexus 5 Antenna Cable Replacement, Remove and Replace the Antenna Cables: stap 4, afbeelding 2 van 3 Nexus 5 Antenna Cable Replacement, Remove and Replace the Antenna Cables: stap 4, afbeelding 3 van 3
    • The antenna cables are located on the right and left side of the battery (one is gray, the other is black).
    • Using your plastic spudger, disconnect both ends of the antenna cables.
    • Connect your new antenna cables.
    • Make sure the antenna cables are securely connected.
  5. Nexus 5 Antenna Cable Replacement, Reassemble the Device: stap 5, afbeelding 1 van 2 Nexus 5 Antenna Cable Replacement, Reassemble the Device: stap 5, afbeelding 2 van 2
    • Screw the midframe and speaker assembly back into place.
    • Push the outer edges of the battery door down until you hear the plastic clips "click."
    • Hold the power button until you feel the phone vibrate and/or see the Google logo displayed.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Tyler Caldwell
181 Reputatie
1 Handleiding geschreven
IUPUI, Team S1-G1, Baechle Fall 2017 Lid van IUPUI, Team S1-G1, Baechle Fall 2017
IUPUI-BAECHLE-F17S1G1
2 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 18
Altijd: 2,782
