Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
This guide shows how to remove and replace the audio port located on the motherboard in the top right-hand corner of the phone.
Wat je nodig hebt
Gereedschap gebruikt in deze stap:SIM Card Eject Tool$2.99
Power off the phone, by long-pressing the power button and touching Power off.
Remove the SIM tray using the SIM Card Eject Tool.
Gereedschap gebruikt in deze stap:T5 Torx Screwdriver$5.49
Remove the two screws from the bottom of the phone with a T5 Torx Screwdriver.
Remove the two 1.8 mm Phillips screws holding down the battery connector.
Using a plastic opening tool, disconnect the battery cable from its socket on the motherboard.
Gereedschap gebruikt in deze stap:Plastic Cards$2.99
Remove the blue tape that secures the white antenna cable to the battery.
Using a spudger, carefully disconnect the white antenna cable.
Carefully pry the battery out with a Plastic Opening Tool, starting at the top left-hand corner and working down towards the bottom right-hand corner.
Remove the nine 4.6 mm Phillips #000 screws. Gently lift out the plastic cover.
The midframe is held in with two clips, one at either side. Use a plastic spudger to release each side and gently lift up and away.
Using a spudger, pop off the gray connector on the top right of the motherboard.
26 andere personen hebben deze handleiding voltooid.
Één opmerking
where can I order the original connector on my Nexus 4? With delivery to the Crimea.
Grateful for the answer in advance.
