Ga door naar hoofdinhoud
Nexus 10 Front Facing Camera Replacement
Wat je nodig hebt
  1. Nexus 10 Front Facing Camera Replacement, Front-Facing Camera: stap 1, afbeelding 1 van 3 Nexus 10 Front Facing Camera Replacement, Front-Facing Camera: stap 1, afbeelding 2 van 3 Nexus 10 Front Facing Camera Replacement, Front-Facing Camera: stap 1, afbeelding 3 van 3
    • Remove the plastic cover located on the back of the device by prying off one side of the cover with a plastic opening device and peeling it back.
  2. Nexus 10 Front Facing Camera Replacement: stap 2, afbeelding 1 van 3 Nexus 10 Front Facing Camera Replacement: stap 2, afbeelding 2 van 3 Nexus 10 Front Facing Camera Replacement: stap 2, afbeelding 3 van 3
    • Pry the device apart by inserting a plastic opening tool in the seam between the plastic backing and display assembly. Use the tool to unclip the plastic tabs in between the backing and the display.
    • Pull the the plastic backing off the display assembly using your hands.
    • Do not do this step with only your hands. You will require a significant amount of force to separate the device.
  3. Nexus 10 Front Facing Camera Replacement: stap 3, afbeelding 1 van 3 Nexus 10 Front Facing Camera Replacement: stap 3, afbeelding 2 van 3 Nexus 10 Front Facing Camera Replacement: stap 3, afbeelding 3 van 3
    • Lift latch on front-facing camera connector.
    • Pull the connector toward the top of the device and remove the front-facing camera.
Conclusie
Benjamin Troller
2.218 Reputatie
5 handleidingen geschreven
Cal Poly, Team 34-18, Maness Spring 2016 Lid van Cal Poly, Team 34-18, Maness Spring 2016
CPSU-MANESS-S16S34G18
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 25
Altijd: 636
