Ga door naar hoofdinhoud
Nextplay NP109CR Speakers Replacement
Wat je nodig hebt
  1. Nextplay NP109CR Speakers Replacement, Speakers: stap 1, afbeelding 1 van 1
    • Turn the device over so it is upside-down.
  2. Nextplay NP109CR Speakers Replacement: stap 2, afbeelding 1 van 1
    • Unscrew the 4 screws closest to the screen.
  3. Nextplay NP109CR Speakers Replacement: stap 3, afbeelding 1 van 1
    • Flip over the device so it is right side up.
  4. Nextplay NP109CR Speakers Replacement: stap 4, afbeelding 1 van 1
    • Unscrew the 2 screws on the top of the device, next to the docking plug.
  5. Nextplay NP109CR Speakers Replacement: stap 5, afbeelding 1 van 1
    • Take off top piece by using slight force and pulling off.
  6. Nextplay NP109CR Speakers Replacement: stap 6, afbeelding 1 van 1
    • Unscrew the button board with smaller screwdriver.
  7. Nextplay NP109CR Speakers Replacement: stap 7, afbeelding 1 van 1
    • Lift off the button board.
  8. Nextplay NP109CR Speakers Replacement: stap 8, afbeelding 1 van 1
    • Unscrew all visible of the screws on the black logic board cover with the larger screwdriver.
  9. Nextplay NP109CR Speakers Replacement: stap 9, afbeelding 1 van 1
    • Lift the screen vertically straight up.
    • As you do this the logic board should move off with it.
  10. Nextplay NP109CR Speakers Replacement: stap 10, afbeelding 1 van 1
    • Flip the screen and the logic board over to the right side.
  11. Nextplay NP109CR Speakers Replacement: stap 11, afbeelding 1 van 1
    • Pull out the white plug that goes from the speakers to the logic board.
    • Then plug back in making sure it is completely connected.
Conclusie
Michelle Read
1 Reputatie
1 Handleiding geschreven
Cal Poly, Team 7-50, Forte Fall 2012 Lid van Cal Poly, Team 7-50, Forte Fall 2012
CPSU-FORTE-F12S7G50
5 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 410
