Ga door naar hoofdinhoud
Inleiding
The button sheet on the Nextplay NP109CR is sometimes placed incorrectly on the device. This prevents the buttons from working correctly. This guide will fix and place the buttons correctly on to the sheet. Use this guide to disassemble the device to reach the buttons. Follow the step by step instructions to re-position the buttons.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
  1. Unscrew the two screws with a Phillips #0 screwdriver on the top side of the device right in front of the eight buttons.
    • Unscrew the two screws with a Phillips #0 screwdriver on the top side of the device right in front of the eight buttons.
  2. Remove the lid from the device.
    • Remove the lid from the device.
  3. Unscrew the four screws with a Phillips #0 Screwdriver from the pink button sheet.
    • Unscrew the four screws with a Phillips #0 Screwdriver from the pink button sheet.
  4. Remove the pink button sheet from the device by pulling out each button. Remove the pink button sheet from the device by pulling out each button.
    • Remove the pink button sheet from the device by pulling out each button.
Conclusie
Reverse these steps to reassemble the device.
Één andere persoon heeft deze handleiding voltooid.
Chotipong Chamchalaem
83 Reputatie
2 handleidingen geschreven
Cal Poly, Team 7-50, Forte Fall 2012 Lid van Cal Poly, Team 7-50, Forte Fall 2012
CPSU-FORTE-F12S7G50
5 Leden
7 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 275
