Ga door naar hoofdinhoud
Nextbook NEXT7P12-8G Camera Replacement
Wat je nodig hebt
  1. Nextbook NEXT7P12-8G Camera Replacement, Camera: stap 1, afbeelding 1 van 1
    • Use the plastic opening tool to pry apart the front and back covers of the Nextbook
    • Continue prying until the front and back covers are completely separated. Use the suction cup if necessary to pull apart
    • We recommend using an extra plastic opening tool to maintain your opening
  2. Nextbook NEXT7P12-8G Camera Replacement: stap 2, afbeelding 1 van 1
    • Once the front and back covers have been separated, set the back cover down and examine the interior of the Nextbook
    • Remove the various pieces of masking tape
  3. Nextbook NEXT7P12-8G Camera Replacement: stap 3, afbeelding 1 van 1
    • Carefully peel the battery pack off, starting from the outer edges
    • It is held down by an adhesive going diagonally across the back
    • Removing the battery will allow you to access the screws holding the chip in place
  4. Nextbook NEXT7P12-8G Camera Replacement: stap 4, afbeelding 1 van 1
    • Use a 4.0 bit screwdriver to remove the screws from the chip
  5. Nextbook NEXT7P12-8G Camera Replacement: stap 5, afbeelding 1 van 1
    • Remove the entire chip by severing small adhesive strips along the edges and pulling the chip away from the frame
    • Carefully peel away the black tape with copper detail that is holding the chip to the device
  6. Nextbook NEXT7P12-8G Camera Replacement: stap 6, afbeelding 1 van 1
    • Locate the camera
    • The camera will be a small black square directly behind the camera lens visible on the front side of the Nextbook
    • Pry the camera out of the front cover with the plastic opening tool
  7. Nextbook NEXT7P12-8G Camera Replacement: stap 7, afbeelding 1 van 1
    • Replace with a spare camera piece
Conclusie
Grace Cho
3 Reputatie
1 Handleiding geschreven
Ohio State, Team 2-2, Garvin Fall 2015 Lid van Ohio State, Team 2-2, Garvin Fall 2015
OSU-GARVIN-F15S2G2
3 Leden
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 806
