Ga door naar hoofdinhoud
Nextbook Flexx 10 Speaker Replacement
Wat je nodig hebt
  1. Nextbook Flexx 10 Speaker Replacement, Back Cover: stap 1, afbeelding 1 van 2 Nextbook Flexx 10 Speaker Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • To begin, turn off the power to the device and remove the screen from the keyboard.
    • Open the 2-in-1, and hold the screen.
    • Press the silver button at the top of the keyboard.
    • When the screen lifts up, gently lift the screen away from the keyboard.
  2. Nextbook Flexx 10 Speaker Replacement: stap 2, afbeelding 1 van 3 Nextbook Flexx 10 Speaker Replacement: stap 2, afbeelding 2 van 3 Nextbook Flexx 10 Speaker Replacement: stap 2, afbeelding 3 van 3
    • You may use your fingers, or a spudger. Be careful not to break your cover OR your fingernail. Removing the cover requires good judgement.
    • The goal is to separate the black from the silver. Start in a corner, or a flat edge -- whichever works best for you. Remember to not use too much force.
    • Once you start the initial separation, keep going until you free one edge. The goal now is to free three edges of the rectangle.
    • If your progress stops on one side of the rectangle, go to the other side and try there.
  3. Nextbook Flexx 10 Speaker Replacement: stap 3, afbeelding 1 van 2 Nextbook Flexx 10 Speaker Replacement: stap 3, afbeelding 2 van 2
    • Gently pull the back cover from the screen assembly.
    • Keep the plastic cover close. It's great for holding screws!
    • When putting the cover back on, press firmly around to outside edge with the screen facing down on a flat, debris-free surface.
  4. Nextbook Flexx 10 Speaker Replacement, Speakers: stap 4, afbeelding 1 van 1
    • See the first image to see the position of the speakers and their connections.
  5. Nextbook Flexx 10 Speaker Replacement: stap 5, afbeelding 1 van 3 Nextbook Flexx 10 Speaker Replacement: stap 5, afbeelding 2 van 3 Nextbook Flexx 10 Speaker Replacement: stap 5, afbeelding 3 van 3
    • To remove the speaker shown in the picture:
    • Remove both screws with a small Philips head screwdriver.
    • Look at how the connector sits, and how the wires are routed. You will need to put these back in the same orientation during reassembly.
    • Gently remove connector and replace assembly if needed.
  6. Nextbook Flexx 10 Speaker Replacement: stap 6, afbeelding 1 van 3 Nextbook Flexx 10 Speaker Replacement: stap 6, afbeelding 2 van 3 Nextbook Flexx 10 Speaker Replacement: stap 6, afbeelding 3 van 3
    • Gently pry speaker free.
    • Carefully pull cable free to connector.
    • Gently remove connector.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 7
Altijd: 451
