Ga door naar hoofdinhoud
Nextbook 8 Battery Replacement
Wat je nodig hebt
  1. Nextbook 8 Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Nextbook 8 Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Use the plastic opening tool to remove the back cover. Carefully slide the tool between the front glass and back cover.
    • Slide the tool along the edge to work the back cover off.
    • It helps to have an extra tool to stick in the gap and keep the back cover separated from the glass as you slide the other tool.
  2. Nextbook 8 Battery Replacement: stap 2, afbeelding 1 van 2 Nextbook 8 Battery Replacement: stap 2, afbeelding 2 van 2
    • Remove the tape covering the motherboard.
    • Remove the silver tape holding the white ribbon cables to the battery.
  3. Nextbook 8 Battery Replacement: stap 3, afbeelding 1 van 2 Nextbook 8 Battery Replacement: stap 3, afbeelding 2 van 2
    • Use a spudger to carefully disconnect the battery connector from the motherboard.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
  4. Nextbook 8 Battery Replacement: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Use a spudger to lift up the black bar on the two ZIF connectors located above the battery.
    • Pull the ribbon cables out of the connectors with tweezers or two fingers.
  5. Nextbook 8 Battery Replacement: stap 5, afbeelding 1 van 2 Nextbook 8 Battery Replacement: stap 5, afbeelding 2 van 2
    • Using the flat end of a spudger, carefully work the spudger under the battery, lifting it off of the device.
    • The battery is very malleable, so do not try to pull it off all at once.
Conclusie
24 andere personen hebben deze handleiding voltooid.
Dylan Wiese
1.889 Reputatie
5 handleidingen geschreven
Colorado Springs, Team 5-1, Panko Spring 2015 Lid van Colorado Springs, Team 5-1, Panko Spring 2015
UCCS-PANKO-S15S5G1
3 Leden
10 handleidingen geschreven
5Gids Commentaar
Very helpful and well made.
Quentin Freed - Antwoord Deel
Where can I buy the battery???
scruff67 - Antwoord Deel
Check Ebay. That's where I'm headed right now.
Tina Carey - Deel
im having connection issues i cant find any wifi period
crusher309 - Antwoord Deel
Hello,
Yes well, but what is th voltage battery?
Thanks
Tyeroued - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 53
Altijd: 43,043
