Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Place device so that the top cover is facing you.
Open the top cover.
Remove the four hex nuts and lock washers (two at each hinge) that secure the cover to the hinges on the left side of the pneumatic box.
Remove the cover and set aside. Retain hardware for re-assembly.
Remove the four screws and washers at the top edge of the right side panel.
Remove the two screws and washers from the underside of the right side panel.
Remove the right side panel. Retain hardware for re-assembly.
