Deze stap is niet vertaald. Help het te vertalen
Place device so that the top cover is facing you.
Open the top cover.
Remove the four hex nuts and lock washers (two at each hinge) that secure the cover to the hinges on the left side of the pneumatic box.
Remove the cover and set aside. Retain hardware for re-assembly.
Carefully place the GDU on its right side with the front of the GDU facing you.
Remove the three screws and washers at the top edge of the left side panel.
Remove the two screws and washers from the underside of the left side panel.
Remove the left side panel. Retain hardware for re-assembly.
Remove the four screws and washers at the top edge of the right side panel.
Remove the two screws and washers from the underside of the right side panel.
Remove the right side panel. Retain hardware for re-assembly.
Remove the three screws and washers that secure the flow sensor cover to the pneumatic box assembly. Retain the hardware for re-assembly.
Pull up and remove the flexible rubber exhalation outlet boot (push fit).
Disconnect the tubes from both sides of the flow sensor and the two tubes from the exhalation valve.
Pull the exhalation module straight up to remove it from the GDU.
Remove the two screws and washers (back corners), one screw and washer (exhalation module support bracket), and two standoffs and washers (front corners) that secure the pneumatic (upper) box assembly to the electronic box assembly. Lift the Pneumatics Box and carefully tilt to one side.
Remove cables from connectors J1, J2, J3, J4, J5, and J6 on the main PCB (4 connectors are not shown due to being blocked by the side panel). Note the position of these connectors for re-assembly.
If not already detached, remove the heater cables from J5 and J6 on the DC-DC power supply PCB.
Bijna klaar!
Eindstreep
