Inleiding
The pneumatic box is a very important removal step and requires the user to be very careful when removing. It is important to note that the guide removal begins on page 44 of the service manual. When reinstalling, the user must read the reinstalling instructions located on page 45 of the service manual.
Wat je nodig hebt
Place device so that the top cover is facing you.
Open the top cover.
Carefully place the GDU on its right side with the front of the GDU facing you.
Remove the three screws and washers at the top edge of the left side panel.
Remove the three screws and washers that secure the flow sensor cover to the pneumatic box assembly. Retain the hardware for re-assembly.
Pull up and remove the flexible rubber exhalation outlet boot (push fit).
Remove the two screws and washers (back corners), one screw and washer (exhalation module support bracket), and two standoffs and washers (front corners) that secure the pneumatic (upper) box assembly to the electronic box assembly. Lift the Pneumatics Box and carefully tilt to one side.
