Inleiding
This guide will cover the removal and replacement of the alarm speaker inside the Newport e500. This operation will require a torque wrench and Philips screwdriver. The alarm speaker is located on the back panel. For more information refer to page 79 of the service manual.
Wat je nodig hebt
Place device so that the top cover is facing you.
Open the top cover.
Pull up and remove the flexible rubber exhalation outlet boot (push fit).
Unscrew the alarm retaining ring from the outside of the back panel; then pull the speaker from the inside of the back panel.
