Ga door naar hoofdinhoud
Biomed
Medische apparatuur
Noch iFixit, noch deze reparatiehandleiding worden onderschreven door of zijn gelieerd aan de fabrikant van de desbetreffende medische apparatuur.
Biomed
Inleiding
This guide will cover the removal and replacement of the alarm speaker inside the Newport e500. This operation will require a torque wrench and Philips screwdriver. The alarm speaker is located on the back panel. For more information refer to page 79 of the service manual.
  1. Newport e500 Alarm Speaker Disassembly, Newport e500 Top Cover Disassembly: stap 1, afbeelding 1 van 1
    • Place device so that the top cover is facing you.
    • Open the top cover.
  2. Newport e500 Alarm Speaker Disassembly: stap 2, afbeelding 1 van 1
    • Remove the four hex nuts and lock washers (two at each hinge) that secure the cover to the hinges on the left side of the pneumatic box.
  3. Newport e500 Alarm Speaker Disassembly: stap 3, afbeelding 1 van 1
    • Remove the cover and set aside. Retain hardware for re-assembly.
  4. Newport e500 Alarm Speaker Disassembly, Newport e500 Exhalation Module Disassembly: stap 4, afbeelding 1 van 1
    • Pull up and remove the flexible rubber exhalation outlet boot (push fit).
  5. Newport e500 Alarm Speaker Disassembly: stap 5, afbeelding 1 van 1
    • Disconnect the tubes from both sides of the flow sensor and the two tubes from the exhalation valve.
  6. Newport e500 Alarm Speaker Disassembly: stap 6, afbeelding 1 van 1
    • Pull the exhalation module straight up to remove it from the GDU.
  7. Newport e500 Alarm Speaker Disassembly, Newport e500 Alarm Speaker Disassembly: stap 7, afbeelding 1 van 1
    • Unscrew the alarm retaining ring from the outside of the back panel; then pull the speaker from the inside of the back panel.
  8. Newport e500 Alarm Speaker Disassembly: stap 8, afbeelding 1 van 1
    • Disconnect the alarm cable assembly from P5 on the back panel PCB.
Conclusie
Jeremy
589 Reputatie
6 handleidingen geschreven
Cal Poly, Team S7-G16, Paton Spring 2020 Lid van Cal Poly, Team S7-G16, Paton Spring 2020
CPSU-PATON-S20S7G16
3 Leden
13 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 37
