Inleiding
This guide will take you through the process involved with removing a capacitor. De-soldering and soldering will be required.
Wat je nodig hebt
Remove the clear plastic casing by lifting it straight up from the router.
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
looks like that's a 220microF at 25V right ?
probably better to replace it with a similar 220microF, but with higher voltage rating.
