Inleiding
How to remove the plastic housing of the camera to either replace it, or remove it to get to the internals of the camera.
Wat je nodig hebt
Locate unlock switch on underside of camera and unlock it by sliding it.
Once unlocked, slide the cover out and up to open the battery housing.
Één andere persoon heeft deze handleiding voltooid.
2 opmerkingen
Note that under the rubber cover shown in step 6 there is a USB-B port.
You can run the Arlo on a USB adapter as well.
You only need to make a hole in the battery lid or 3D print a new cover.
