Ga door naar hoofdinhoud
Nest Thermostat E Base Plate Replacement
Wat je nodig hebt
  1. Nest Thermostat E Base Plate Replacement, Base Plate: stap 1, afbeelding 1 van 1
    • Grasp the display's outer ring with your fingers and pull directly away while rotating clockwise to remove the thermostat from the wall.
    • Go to the electrical panel and turn off the circuit to make sure no power is running to the thermostat.
    • Once the power is off, disconnect the Y1, G, R, W1, C, and OB wires.
    • Remember the placement of each wire for reassembly.
  2. Nest Thermostat E Base Plate Replacement: stap 2, afbeelding 1 van 1
    • Remove the two 1 ¼” drywall screws holding the base display and base plate in the wall using a Phillips #2 screwdriver.
    • Remove the base plate and base display.
  3. Nest Thermostat E Base Plate Replacement: stap 3, afbeelding 1 van 1
    • Pry the base display off of the baseplate using an iFixit opening tool.
Conclusie
Andrew Ahlborn
368 Reputatie
3 handleidingen geschreven
Één opmerking
Any recommendations on where to get 2nd and 3rd gen base plates. Both burned by lightning...
elippert - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 27
Altijd: 472
