Ga door naar hoofdinhoud
Nest Hello O-Ring Replacement
Wat je nodig hebt
  1. Nest Hello O-Ring Replacement, Casing and Faceplate: stap 1, afbeelding 1 van 1
    • Insert the pick between the black faceplate and white casing of the Nest Hello.
    • Pry the faceplate away from the device with the opening pick.
    • If you have not opened the Nest Hello before, there will be a protective foam mesh that is glued to the plastic covering and the inside of the mesh, use a pick to cut through the mesh as much as possible.
    • Completely remove the faceplate from the device, do not be afraid to pull hard.
  2. Nest Hello O-Ring Replacement: stap 2, afbeelding 1 van 2 Nest Hello O-Ring Replacement: stap 2, afbeelding 2 van 2
    • Peel back the cover stickers and use the Phillips #000 screwdriver to remove the four screws.
  3. Nest Hello O-Ring Replacement: stap 3, afbeelding 1 van 3 Nest Hello O-Ring Replacement: stap 3, afbeelding 2 van 3 Nest Hello O-Ring Replacement: stap 3, afbeelding 3 van 3
    • Insert opening pick between the white casing and the black internal circuitry and pry it out.
    • There is a ribbon cable connecting the white casing to the circuit boards. Be careful not to tear out the cable while separating the casing from the circuit boards.
  4. Nest Hello O-Ring Replacement, O-Ring: stap 4, afbeelding 1 van 1
    • Remove the O-Ring (colored blue) from the device. It is placed around the edge of the motherboard.
Conclusie
3 andere personen hebben deze handleiding voltooid.
2Gids Commentaar
Is there a link available for spare replacement parts? I can’t seem to find anything other than replacement internal batteries . Thanks!
Andres Chavez - Antwoord Deel
Also looking for this replacement part. Googling did not produce results.
KB_KB - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 30
Afgelopen 30 dagen: 101
Altijd: 5,079
