Ga door naar hoofdinhoud
Nest Cam Outdoor S Internal Camera Replacement
Wat je nodig hebt
  1. Nest Cam Outdoor S Internal Camera Replacement, Plastic Camera Cover: stap 1, afbeelding 1 van 2 Nest Cam Outdoor S Internal Camera Replacement, Plastic Camera Cover: stap 1, afbeelding 2 van 2
    • Wedge a spudger between the black front panel and the white outer shell.
    • Slide the spudger around the edge of the panel to pop it off.
  2. Nest Cam Outdoor S Internal Camera Replacement: stap 2, afbeelding 1 van 1
    • Remove the four small screws from the plastic camera cover.
  3. Nest Cam Outdoor S Internal Camera Replacement: stap 3, afbeelding 1 van 1
    • Disconnect the microphone cable to separate the motherboard from the main camera unit.
  4. Nest Cam Outdoor S Internal Camera Replacement: stap 4, afbeelding 1 van 2 Nest Cam Outdoor S Internal Camera Replacement: stap 4, afbeelding 2 van 2
    • Remove the plastic camera cover from the device.
  5. Nest Cam Outdoor S Internal Camera Replacement, Internal Camera: stap 5, afbeelding 1 van 1
    • Pry the plastic cover away from the motherboard at the plastic clips using a spudger.
  6. Nest Cam Outdoor S Internal Camera Replacement: stap 6, afbeelding 1 van 1
    • Remove the four mounting screws from the motherboard.
  7. Nest Cam Outdoor S Internal Camera Replacement: stap 7, afbeelding 1 van 1
    • Disconnect the yellow camera cable from the motherboard.
    • Remove the camera from the device.
Conclusie
Skylar DeVoe
235 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 4-6, Gulbrandsen Fall 2021 Lid van UMass Dartmouth, Team 4-6, Gulbrandsen Fall 2021
UMASSD-GULBRANDSEN-F21S4G6
2 Leden
4 handleidingen geschreven
2 opmerkingen
Can you replace the corn to the actual camera
Cathy Willis - Antwoord
Can you replace the corn to actual camera
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 37
Altijd: 1,668
