Ga door naar hoofdinhoud
Nest Cam IQ Motherboard Replacement
Wat je nodig hebt
  1. Nest Cam IQ Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 1
    • To soften the adhesive holding the camera together, heat up the edges of the glass lens using a heated iOpener on the device. Alternatively, you can use a heat gun to loosen the adhesive.
    • Leave the Opener on the glass lens for two minutes.
    • Be careful not to burn yourself while handling the hot iOpener. For more information on the Opener, use the iOpener Instructions Guide.
  2. Nest Cam IQ Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Use an opening tool to split apart the glass lens from the body.
    • Be careful to not break the glass when prying from the body.
  3. Nest Cam IQ Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Place a suction cup on the glass lens that you heated up with the iOpener.
    • Press down on the suction cup to create a seal, and pull up with force to create a separation between the glass lens and the body.
    • Pull off the glass lens using the suction cup.
  4. Nest Cam IQ Motherboard Replacement: stap 4, afbeelding 1 van 2 Nest Cam IQ Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Carefully disconnect the flat black ribbon cable connecting the metal plate to the LED.
    • Remove the metal plate.
  5. Nest Cam IQ Motherboard Replacement: stap 5, afbeelding 1 van 2 Nest Cam IQ Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Remove the five 9 mm TR6 Torx screws from the LED cover.
    • Pull off the LED cover.
    • As you remove the LED cover, be careful not to tear the flat black ribbon connecting the LED to the motherboard.
  6. Nest Cam IQ Motherboard Replacement: stap 6, afbeelding 1 van 3 Nest Cam IQ Motherboard Replacement: stap 6, afbeelding 2 van 3 Nest Cam IQ Motherboard Replacement: stap 6, afbeelding 3 van 3
    • Carefully disconnect the flat black ribbon cable connecting the LED to the motherboard.
    • Remove the LED cover.
  7. Nest Cam IQ Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Remove the two 7 mm TR6 Torx screws securing the camera.
    • Carefully pull out the camera.
    • As you remove the camera, be careful not to tear the flat black ribbon connecting the camera to the motherboard.
  8. Nest Cam IQ Motherboard Replacement: stap 8, afbeelding 1 van 2 Nest Cam IQ Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Carefully disconnect the flat black ribbon cable connecting the camera to the motherboard.
    • Remove the camera.
  9. Nest Cam IQ Motherboard Replacement: stap 9, afbeelding 1 van 3 Nest Cam IQ Motherboard Replacement: stap 9, afbeelding 2 van 3 Nest Cam IQ Motherboard Replacement: stap 9, afbeelding 3 van 3
    • Remove the three 19 mm TR6 Torx screws from the camera holder.
    • Carefully lift the tab up and away from the camera holder.
    • Remove the camera holder.
  10. Nest Cam IQ Motherboard Replacement: stap 10, afbeelding 1 van 2 Nest Cam IQ Motherboard Replacement: stap 10, afbeelding 2 van 2
    • Remove the one 4 mm TR6 Torx screw from the clear cover.
    • Remove the clear cover.
  11. Nest Cam IQ Motherboard Replacement: stap 11, afbeelding 1 van 3 Nest Cam IQ Motherboard Replacement: stap 11, afbeelding 2 van 3 Nest Cam IQ Motherboard Replacement: stap 11, afbeelding 3 van 3
    • Remove the four 11 mm TR6 Torx screws from the clamp securing the mounting stand.
    • Remove the clamp.
    • Carefully pull away the cables connecting the mounting stand to the body.
  12. Nest Cam IQ Motherboard Replacement: stap 12, afbeelding 1 van 3 Nest Cam IQ Motherboard Replacement: stap 12, afbeelding 2 van 3 Nest Cam IQ Motherboard Replacement: stap 12, afbeelding 3 van 3
    • Carefully remove the mounting stand.
    • Remove the three 9 mm TR6 Torx connecting the motherboard and speaker to the body.
    • Pull the motherboard and speaker from the body.
  13. Nest Cam IQ Motherboard Replacement: stap 13, afbeelding 1 van 3 Nest Cam IQ Motherboard Replacement: stap 13, afbeelding 2 van 3 Nest Cam IQ Motherboard Replacement: stap 13, afbeelding 3 van 3
    • Remove the one 8 mm TR6 Torx screws securing the speaker to the motherboard.
    • Remove the two 4 mm TR6 Torx screws securing the speaker to the motherboard.
    • Carefully pull away the speaker.
    • As you pull away the speaker, be careful not to damage the cable connecting the speaker to the motherboard.
    • Carefully disconnect the cable connecting the speaker to the motherboard.
  14. Nest Cam IQ Motherboard Replacement: stap 14, afbeelding 1 van 3 Nest Cam IQ Motherboard Replacement: stap 14, afbeelding 2 van 3 Nest Cam IQ Motherboard Replacement: stap 14, afbeelding 3 van 3
    • Remove the four 4 mm TR6 Torx screws securing the motherboard.
    • Remove the two 5 mm 3.5 low-head socket cap screws securing the motherboard.
    • Remove the motherboard.
Conclusie
Jas Ownby
800 Reputatie
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 93
