Ga door naar hoofdinhoud
Nest Cam IQ Lens Replacement
Wat je nodig hebt
  1. Nest Cam IQ Lens Replacement, Lens: stap 1, afbeelding 1 van 1
    • To soften the adhesive holding the camera together, heat up the edges of the glass lens using a heated iOpener on the device. Alternatively, you can use a heat gun to loosen the adhesive.
    • Leave the Opener on the glass lens for two minutes.
    • Be careful not to burn yourself while handling the hot iOpener. For more information on the Opener, use the iOpener Instructions Guide.
  2. Nest Cam IQ Lens Replacement: stap 2, afbeelding 1 van 1
    • Use an opening tool to split apart the glass lens from the body.
    • Be careful to not break the glass when prying from the body.
  3. Nest Cam IQ Lens Replacement: stap 3, afbeelding 1 van 1
    • Place a suction cup on the glass lens that you heated up with the iOpener.
    • Press down on the suction cup to create a seal, and pull up with force to create a separation between the glass lens and the body.
    • Pull off the glass lens using the suction cup.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jas Ownby
800 Reputatie
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 22
Altijd: 182
