Ga door naar hoofdinhoud
Nespresso U inner coffee spout replacement
Wat je nodig hebt
  1. Nespresso U inner coffee spout replacement, Internal coffee spout: stap 1, afbeelding 1 van 2 Nespresso U inner coffee spout replacement, Internal coffee spout: stap 1, afbeelding 2 van 2
    • Insert an opening tool into the gap between the coffee spout and the side panel on the right side. Push the side panel away a few millimeters and push the tool down until the side panel at the front edge comes loose with a loud crack
    • Repeat on the left side.
  2. Nespresso U inner coffee spout replacement: stap 2, afbeelding 1 van 2 Nespresso U inner coffee spout replacement: stap 2, afbeelding 2 van 2
    • Push the side parts apart at the top.
    • Lift out the coffee spout, it is held in place by detents.
  3. Nespresso U inner coffee spout replacement: stap 3, afbeelding 1 van 1
    • Plug in the connector and turn on the machine.
    • Push the slider for the capsule forward until the motor moves the brewing unit forward, when it is half way, then gently push the slider back so that the brewing unit stops half way.
    • Pull the power plug.
  4. Nespresso U inner coffee spout replacement: stap 4, afbeelding 1 van 2 Nespresso U inner coffee spout replacement: stap 4, afbeelding 2 van 2
    • Now you can lift out the defective inner coffee spout. Its retaining tabs are probably broken off, so this should be quite easy.
  5. Nespresso U inner coffee spout replacement: stap 5, afbeelding 1 van 2 Nespresso U inner coffee spout replacement: stap 5, afbeelding 2 van 2
    • The two broken tabs are clearly visible. In the second picture, the old and the new part are next to each other.
  6. Nespresso U inner coffee spout replacement: stap 6, afbeelding 1 van 2 Nespresso U inner coffee spout replacement: stap 6, afbeelding 2 van 2
    • Take the opportunity to clean the spout rocker and all internal parts.
  7. Nespresso U inner coffee spout replacement: stap 7, afbeelding 1 van 1
    • Press firmly on the new coffee spout.
  8. Nespresso U inner coffee spout replacement: stap 8, afbeelding 1 van 3 Nespresso U inner coffee spout replacement: stap 8, afbeelding 2 van 3 Nespresso U inner coffee spout replacement: stap 8, afbeelding 3 van 3
    • The broken upper flap is still present here. Lift it out with tweezers.
Conclusie
Work through the steps in reverse order to reassemble your device.
3 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
de en
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
VauWeh
207.570 Reputatie
255 handleidingen geschreven
Repair is War on Entropy Lid van Repair is War on Entropy
Community
26 Leden
1.176 handleidingen geschreven
3 opmerkingen
Estos pasos que me indica ya los he realizado lo que ahora necesito es seguir desmontando la máquina para acceder a la parte movible que prensa la cápsula, para poder actuar a ese nivel y proder a la limpieza profunda de todo el conjunto
Gracias y espero que me pueda orientar para el desmlntaje completo de la máquina
losdo85 - Antwoord
I have already carried out these steps that you indicate, what I now need is to continue disassembling the machine to access the movable part that presses the capsule, to be able to act at that level and proceed to deep clean the entire assembly.
Thank you and I hope you can guide me for the complete dismantling of the machine
losdo85 - Antwoord
Sorry - to date, I have not had to open this machine any further. But maybe these instructions do help you: Nespresso CitiZ Brüheinheit tauschen
VauWeh -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 40
Afgelopen 30 dagen: 176
Altijd: 2,569
