Ga door naar hoofdinhoud
Nerf Vortex Vigilon Slide Replacement
Wat je nodig hebt
  1. Nerf Vortex Vigilon Slide Replacement, Removing the slide screws: stap 1, afbeelding 1 van 1
    • The two slide pieces hold the orange sight in place. Expect that the sight will come off when you remove the slide pieces.
    • Using a screwdriver, carefully unscrew the three #00 1 cm Phillips screws holding the two slide pieces together.
    • Both sides of the slide will come off when the screws are removed.
  2. Nerf Vortex Vigilon Slide Replacement, Removing the slide pieces: stap 2, afbeelding 1 van 1
    • Lift both slide pieces off of the gun.
Conclusie
Cara Pew
911 Reputatie
7 handleidingen geschreven
Cal Poly, Team 13-6, Forte Fall 2014 Lid van Cal Poly, Team 13-6, Forte Fall 2014
CPSU-FORTE-F14S13G6
5 Leden
Één opmerking
Ok so the slide is removed now what? It's still stuck
amanintights1981 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 2,237
