Ga door naar hoofdinhoud
Nerf N-Strike Maverick Catch Spring Replacement
Wat je nodig hebt
  1. Nerf N-Strike Maverick Catch Spring Replacement, Use the Teardown Guide to Open the Gun: stap 1, afbeelding 1 van 1
  2. Nerf N-Strike Maverick Catch Spring Replacement, Remove Large Spring: stap 2, afbeelding 1 van 1
    • Remove the larger spring from the catch mechanism.
  3. Nerf N-Strike Maverick Catch Spring Replacement, Remove the Catch Mechanism & Spring: stap 3, afbeelding 1 van 1
    • Remove the catch mechanism and spring by gently lifting it straight up and off the metal pin that holds it.
    • The catch spring has a tendency to bounce away when removed.
  4. Nerf N-Strike Maverick Catch Spring Replacement, Replace the Catch Spring: stap 4, afbeelding 1 van 1
    • After removing the old catch spring, place the new catch spring back on the tip of the catch mechanism.
    • If you are unable to find an exact replacement, one may be fashioned out of a pen spring.
  5. Nerf N-Strike Maverick Catch Spring Replacement, Putting the Catch Mechanism Back: stap 5, afbeelding 1 van 1
    • Carefully replace the catch mechanism so that it is seated in the grooves and over the metal pin.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Michael Walker
193 Reputatie
1 Handleiding geschreven
University of Maine, Team 1-2, Diaz Fall 2014 Lid van University of Maine, Team 1-2, Diaz Fall 2014
UMAINE-DIAZ-F14S1G2
3 Leden
3 handleidingen geschreven
Één opmerking
do you have a spare catch spring the whole catch mechanism and spring
cowboybebop6968 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 29
Altijd: 7,323
