Ga door naar hoofdinhoud
Nerf N-Strike Firestrike O-Ring and Plunger Replacement
Wat je nodig hebt
  1. Nerf N-Strike Firestrike O-Ring and Plunger Replacement, Remove battery cover: stap 1, afbeelding 1 van 1
    • Use a #1 Phillips screwdriver to remove the 10 -mm screw that secures the battery plate, then remove the battery cover using your hands.
  2. Nerf N-Strike Firestrike O-Ring and Plunger Replacement: stap 2, afbeelding 1 van 2 Nerf N-Strike Firestrike O-Ring and Plunger Replacement: stap 2, afbeelding 2 van 2
    • Slide out the two AAA batteries using your fingers.
  3. Nerf N-Strike Firestrike O-Ring and Plunger Replacement, Blaster Casing: stap 3, afbeelding 1 van 1
    • Remove the seven 10-mm black Phillips screws from the blaster casing with a #1 Phillips Screwdriver.
  4. Nerf N-Strike Firestrike O-Ring and Plunger Replacement: stap 4, afbeelding 1 van 2 Nerf N-Strike Firestrike O-Ring and Plunger Replacement: stap 4, afbeelding 2 van 2
    • Slowly pull apart the blaster casing, starting at the battery location.
    • Keep pulling apart slowly until it separates completely. Be cautious as to not send the internal components flying.
  5. Nerf N-Strike Firestrike O-Ring and Plunger Replacement: stap 5, afbeelding 1 van 2 Nerf N-Strike Firestrike O-Ring and Plunger Replacement: stap 5, afbeelding 2 van 2
    • For reassembly, ensure that the chrome nut gets put back in the proper location, signified by the red box.
    • For reassembly, ensure that all the parts are lined up correctly on the dowels, signified by the four orange boxes.
    • For reassembly, note the location of the springs as highlighted in the second photo.
  6. Nerf N-Strike Firestrike O-Ring and Plunger Replacement, O-Ring and Plunger: stap 6, afbeelding 1 van 3 Nerf N-Strike Firestrike O-Ring and Plunger Replacement, O-Ring and Plunger: stap 6, afbeelding 2 van 3 Nerf N-Strike Firestrike O-Ring and Plunger Replacement, O-Ring and Plunger: stap 6, afbeelding 3 van 3
    • Without removing the barrel assembly, tilt it slightly upwards.
    • Slide the plunger out from the air chamber.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Clovis Jahan
200 Reputatie
1 Handleiding geschreven
Cal Poly, Team 15-6, Amido Spring 2015 Lid van Cal Poly, Team 15-6, Amido Spring 2015
CPSU-AMIDO-S15S15G6
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 30
Altijd: 4,675
