Inleiding
You will be able to disassemble the Firestrike and remove the laser assembly. You will need nothing other than a number 1 Phillips screwdriver and your hands. This guide can be completed anywhere and is relatively straight forward.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Use a #1 Phillips screwdriver to remove the 10 -mm screw that secures the battery plate, then remove the battery cover using your hands.
Remove the seven 10-mm black Phillips screws from the blaster casing with a #1 Phillips Screwdriver.
Remove the laser trigger by grabbing the trigger with your fingers and pulling it up and out.
Remove the firing trigger by grabbing the trigger with your fingers and pulling it up and out.
Gently pull up on the circuit board located near the gun handle until it separates from the gun.
